- Joined
- Aug 3, 2003
- Messages
- 653
- Location
- N C / Illinois
- Corvette
- 1985 Coupe /1977 L82 Coupe / 1971 Red Coupe
Ouch, Thats probably whats going to happen by the time I am ready to start back up with mine !
......when it's completed, french doors and all![]()
Maybe I should have called them "Freedom Doors". :L
The temperature dropped fast this evening and the winds came up. The river is GONE!
Okay, enough of this nonsense. Time to get ready for S-P-R-I-N-G.
My newest question relates to wall-raising.
We built the 20' x 20' garage at my old home by laying out the 20' x 8' walls on the asphalt driveway. Then we nailed the studs to the top and bottom plates and raised them up into place.
QUESTION: What is the best way to build a 36' x 10' wall (overall building is 36' x 36') when there isn't a large enough flat area to lay it out on? I'm worried about not getting the wall square when I build it on unleveled ground? Keep in mind that I'll be raising a wall skeleton (studs only), unlike Scott who raised a wall with exterior panels attached.
What am I missing?![]()
If you have room , build it in 12 X 10 sections and stand them up, tie them together at the top doubling the top band. I could tell you or show you but I have a hard time typing it to make anyone understand me.:bash
Get a couple guys to help carry the sections to a flat place where you can square it and carry it a section at a time and put them in place. Studs only should not be hard to manage that way.
Great suggestion, Scott. Yes, I plan on using two top plates, which will tie the sections together. I can probably prepare a 12' x 10' ground work area to be close to level. If I take care, I can probably get the 12' x 10' sections square and flat enough for this to work out. I'll temporarily nail on some diagonal bracing for the raising step.
My problem was in focusing on building those huge lengths of wall. Splitting each of them into three individual sections makes so much more sense.
Thanks.
I'm going to put an order in for the roof trusses soon. I'm curious to see how much extra a raised centre section will cost.![]()
A word of advise to you, no matter how Superman you feel when the truss arrive, get a boom truck. We set mine by hand and dam near killed all of us more than once. It seems like a good idea at the time but if I ever do it again, I will be watching the boom truck set the truss. :L
Yep, it should do it !There isn't room to bring a boom truck under the low-hanging tree branches, but one of my new friends has this. I'm betting it will be enough help to get the trusses up.
