So, once again I turn to the experts on CAC for some confirmation (or denouncement) of my next steps.
When the back-filling with sand is complete, around the perimeter, I plan to:
1. fill the inside of the building with 3/4 crusher stone up to approximately 9" below floor level;
2. we'll then ensure the most level floor possible by adding an inch or two of sand, bringing the level to exactly one block (8") below the top of the floor;
3. we'll lay down a 10-mil vapour barrier;
4. we'll lay down 2" thick sheets of
Celfort (discussed in posts above), taping the sheets together;
5. we'll pour a 6" slab of 25MPa concrete;
6. we'll spray on a clear concrete sealer the day after the pour.
There is, however, a step missing..........the rebar. In the last garage project I built, the rebar bundles were run across the garage floor in two trenches dug in the stone, from one side to the other, just prior to the pour. Therefore, the rebar bundles got saturated with concrete and became one with the floor.
If I have a vapour barrier and the
Celfort sheets on top of the stone, how do I incorporate rebar in the concrete pour on top of the
Celfort? :confused
I know you guys will have the answer.
