keremarsan
Hi !
After trying to start the car without fuel pump and with accelerating ( something never to do , I learned it with very bad way , don't do this !!!! ) , since I have some strange problems,
even the fuel pump is changed and work perfect now, this electronic problem continues :
My car
1) Can not show the fuel consumption
2) Can not show the Range ( indicates zero )
3) Can not decrease the iddle ( fixed at 1100-1200 RPM ) and irregular sound on iddle.
4) No error code stored
If I connect ALDL A to B
5) it can not begin the diagnosis.
If I start the car with ALDL A to B connected :
My car
RETURNS to NORMAL operating conditions
1) Show the consumption
2) Indicated the Range
3) Can decrease the iddle to 700 RPM
from New Page 3 , I get the information that the A5 pin of ECM ( brown -white cable ) has a possible short to ground problem.
I can use the car as ALDL conncected , but , more strange, the car can begin to diagnosis when the car is running and I understand that this time the car is totally normal and when I disconnect the ALDL , continues to run normally for a certain time, then same problem return ( I understand that the problem returns because suddenly the car again can not shows the consumption and range = 0 and iddle RPM rise to 1100)
I think to change the ECM ,
Can anybody experienced the same problem ? Where is this cable ( brwn - white ) comes from before reaching the ECM ??
I looked the ECM wiring, everything seems clear, but on the firewall part,
these cables are in dusty condition.
My car has now 74400 original miles.
All information is appreciated
Thank you
and I want to say hello to all vette lovers
from Istanbul / Turkey
kerem
My car
My car
Thank you
kerem
