hotshotzny
now i cant be sure if this also pertains to later model c4's or not but i know for sure it had something to do with my 84! so i have changed every sensor there is in my car (and went through the same thing on my 82) and it always seemed to have a stumble somewhere in its stride... so the other night i was under the hood actually trying to find a bad plug wire and i heard a little hissing noise... so as i investigated further i traced it to a filter or check valve (depending who you ask and what part catalog you look at) between the brake booster and the motor.... as soon as i pulled the hose from the filter my car became an entirely new animal... so i pulled the part off and found it to be completly clogged or broken.. my car right now is running better than it ever has and all because of a $6 part so if i were you i would go out start my car and pull that annoying little thng that no one has ever mentioned before off and see what happens
heres a link to the part
http://www.autozone.com/selectedZip...etail/initialR,2004583/shopping/selectZip.htm
http://www.oehq.com/index2.cfm?showpage=utility/partsearch2.cfm&partno=17070814&vendor=ACD
