DWM, Hi, check your door locks see if their working, there's a wire that abrades under both seats, usually the driver seat is the problem since it's used more often. There is a bulletin out on the problem and shows you exactly where and how to correct. Door locks/seats share same circuit breaker. The circuit breaker was VERY hot to the touch on my 88. I found the bulletin on CAC. Hope this helps....
