fastglass95
I have a small problem with the power steering on a 96 LT1.
When warm, the steering is normal EXCEPT when you stop and drop down to idle speed or come to a stop sign or whatever. Then the steering effort increases dramaticaly, you notice it very much when parking.
I've tried replacing the fluid, no help, old fluid looked OK anyway.
Fluid level is fine
No leaks anywhere.
only 25,000 miles on the car.
Belt is brand new and tensioned correctlly, does not appear to slip.
When cold, you will not notice it as much, idle must be slightly higher.
Seems like pump pressure is too low at idle when hot.
Could the pump be going bad already?
Any input would be appreciated,
Thanks,
Fluid level is fine
No leaks anywhere.
Thanks,
