magicv8
BarryK said:I drove it a short ways to see if the air flow from driving would help cool it down but it didn't. Still staying at 215* - 220*.
QUOTE]
Barry - take the car down the highway at 55-65mph. If the temp gauge indicates overheating, the fan isn't the main problem. If the coolant isn't being puked, the gauge may be wrong - notice the green wire running above the LH valve cover - and make sure it is not laying on the center of the intake where the exhaust crossover heats the intake.
Also: Check the lower rad hose to see if there is a spring inside when you squeeze it. If not, look to see if it is collapsing when the tstat opens at 180-195F. It is also possible that the lower hose is self destructing internally and is plugged enough to prevent the rad water from reaching the engine.
PS When you installed the temp sender, you put it in with clean threads (like the factory did) - right? Pipe dope or teflon tape on the threads can screw up the readings.
