Corvette-Pilot
You can still just swap the filter out and add a 1/2 quart of oil. Sure is cheaper than the filter blowing out and trashing the engine
VanityBob said:years ago the filter was accessable under the hood. The top screwed off and inside the canister was a roll of toilet paper, in one we were servicing.
Absolutely correct.rrubel said:Just FYI, you can change your filter without losing more than 1/2 a quart or so of oil. I do it all the time - change filter every 3k miles, oil every 10k. Pre-fill the filter (long as you don't have a ZR-1) and add a little to the crankcase to top it off.
[RICHR]
As a member of the automotive aftermarket parts business for 30 years, FRAM is still #1 when it comes to a poor quality oil filter.
Cut one open sometime... you wouldn't put one on a lawn mower, let alone a Vette.
Well Golleee, learn something new everyday. What brand should we use that's readily avaliable?
Damn, lets make up our miinds. I just got back from AutoZone where I returned all my Frams (2) and got AC Delcos instead. Of course they all thouight I was nuts. I suppose I am sorta....
k&n/mobil/ac delco should be your first choices.
