GT6Steve@aol.com
After a carb failure last week I've developed an engine knock. I'm assuming a lot of raw fuel was dumped into the sump diluting the oil. I had the oil changed on the weekend to be safe but apparently too late. On the way to work Monday a knock developed at 2000 RPM and by the time I arrived it was knocking continuosly. Brought it home on a wrecker...
To the point, Can I pull the pan on the 81 with the engine in place?? The crossmember is pretty wide and I know there's a pickup in the way.
Is there any chance the crank and rod are OK??
I've got two Range Rover engines apart at the moment and don't really fancy another pile of parts floating around.
Thanx in advance, Steve in Las Vegas
