Pulling the torsional damper
USNA1969
Maryland
1972 Big Block/4-Speed
I'm getting ready to pull the torsional damper to replace my timing set. Are there any tricks that will help? Are there any potential snags to avoid?
Thanks,
duke94
Ann Arbor, MI
71' convert and 78' both Red
Just use the correct puller. The kind that uses the 3 bolt holes in the dampener. Don't let the center puller bolt push directly on the end of the crank, screw in a bolt and push on the head of it with the puller so you don't damage the threads in the crank.
yellow77
Tulsa, OK
1977, Bright Yellow
Exactly what Duke said.
Cheers
Richard
Bill75
Somers CT
75 Coupe ZZ4, Brodix IK-180's, Headers,TK0-500
And don't forget to use the correct tool when you put it back on. I have one of these and it works excellent!
rponfick
Lafayette, CO
1969 427-435 roadster
Your friendly Auto Zone or other parts store will be glad to loan you the appropriate tool.
Ralph
