D
devilfish
Has annyone experince with the use of a high rpm manifold and cam, like the miniram with a lt4 hot cam ( or simular ), and stock bottom end? Can u have a stock bottom end L98 and shift at 6200rpm for years and years and not brake it? Or do you basic run a "time bomb" with this setup?
If I should use a miniram lt4 hot cam afr 190 heads, I should have peak HP at 6500rpm ( or higer ), is that safe if you wil use a "light" valve train? And you have a low milage car.
