almost done (except for valve cover and carb..... ) and I only have the distributor, alternator, and belts left to install.
i've been working on the alternator and got it mounting up but than the belt won't reach it enough to slip over the pulley even with the alrernator shifter all the way up as far as it will move.
can you guys please confirm I am running the bels correctly?
1. inside belt (closest to the block):
this is the smaller of the two belts and runs around the crank pulley, the WP pulley and the idler pulley. This one is fitting fine and I just have to adjust tension via the idler pulley.
2. outside belt (closest to the fanblade):
this is the long belt and it runs around the crank pulley, WP pulley and to the alternator and tension would be adjusted via alternator top mount.
does this sound correct?
before disassembly, the alternator was positioned so that it was approx at the halfway point within the long slot on the top mounting bracket. currently, even with the alternator shifted up to the very end of the slot on that beacket closest to the WP the belt is coming up too short and I can't figure out why.
as a reminder, my motor is the L76 - no PS, no PB, no AC.
both crank and WP pulleys are basic 2-groove pulleys.
thanks!
thanks!
