qblue90
- Joined
- Jun 2, 2008
- Messages
- 43
- Location
- S.E. Michigan
- Corvette
- 1990 Quasar Blue 6 spd,Z51,FX3,J55,GT7
I've finally gotten my new FX3's from Bilstein and I can not wait to get them on as my car has felt mushy for quite a long time now. I have a couple questions that I would like to ask to those who have done this job already. I do not want to make any mi$$$takes and I dont want any unnecessary downtime.
To begin, yes I do have the FSM and yes I've read the sections on front and rear shock replacement, but it is somewhat vague on some points. I'm a semi-competent backyard wrencher and I have done shocks/struts on other vehicles before. This job looks easy enough. Its the actuators that worry me.
Looks like all I have to do is pull the actuator retaining clip and the actuator should come right off correct? Does the position of the actuator ie.. Tour, Sport, Perf matter when I go to reinstall on the new shock? For that matter, does the position of the new shock ( again Tour, Sport, Perf) ? Does anyone know what adjustment position Bilstein ships new shocks in? Not sure if that even matters.
It looks like I could probably do this job without jacking up the car and removing the wheels. The FSM states that I should use a jack stand under the control arm for support if I do jack the car up. Should I put some of the weight of the vehicle down on the jack stand to put the suspension in a "ride" position? I hope that question makes sense. So the suspension is not just hanging?
Are there any other things I should be aware of before I begin this job? I just want to make sure I cover all the bases and don't do more harm than good.
I appreciate any help anyone could offer!
