milehigreg
I cleaned out the space between the radiator and A/C condeser this weekend. Leaves, pine needles, cigaratte butts, paper etc. Relatively easy job. Only problem was that the bottom auto trans connection was frozen. I was extremely careful with it because I intended to drive the car to Phoenix next week. My first long road trip. Soaked it it WD-40 and then SeaFoam for two days to no avail. So I left it connected, lifted the condenser coil up and cleaned everything in place. Bottoned everything back up and wentfor a shakedown run. Trans fluid is leaking from the bottom connection.
ad The flare nut never moved. However, I think i might have tweaked the female fitting in the radiator tank. Does anyone know how this fitting works. Does it screw into the plastic tank? Is there any way to tighten it or seal it without removing the radiator? Removing the radiator will require removing /cutting off and repacling the auto trans line. Really want to take it to Phoenix. on Friday but I may be SOL.
