Due to an earlier "mishap" this past December
(http://www.corvetteactioncenter.com/forums/showthread.php?t=77645)
I went out to the garage today to rough adjust the camber on my left rear side. That side had almost all positive camber apparently due to the jarring effect of my off road experience.
While I was down there checking general bolt snugness, I noticed my rear leaf spring pad bolts were almost completely out with the pad under the spring very loose.
I started to hand tighten them up and I found that the two bolts that are near the front of the car would only go so high before they appeared to be bottoming out. I measured these bolts and they are 3-3/4" long. Is that too long for a fiberglass spring?
It wouldn't surprise me if this had always been loose since I purchased the car, since alot of stuff was previously "bubba'd" and the back end has never felt right.
Also, does anyone have torque specs for fiberglass spring bolts?
Here is a picture of what I have. Does the setup look "normal"? I'm not used to a fiberglass spring and was wondering about the plastic looking block between the spring and the rear pumpkin.
(Yeah, the rear end is a filthy mess, the only part of the car I still have to remove and restore)
