- Thread starter
- #21
J
jsimpson
I've been using moly rings for over forty years, and I have yet to see an engine that had properly seated rings with less than a hundred hours running time. Moly isn't magic; the rings and walls still have to develop a mating surface that is flat-to-flat, and synthetic oil inhibits that process. Newer computer designed and conputer controilled building and ssembly merely makes all the tolerances closer when the engine is put together, making it far more likely that the rings will be properly seated when installed.
