Rear Window Question??
Simi Valley, CA USA
1975 Red on RED Coupe
Saw the thread about the 72 removable window shelf. I was wondering if my 75 could be retroed to incorporate the hardware for the rear removeable window. Any thoughts? Jim
People have done it. How, I don't know but would assume they got the needed parts from a Vette salvage dealer. Have not seen any kits for the conversion.
tom...
Here is what is needed to make the conversion..
  • Window with frame
  • Bottom brackets that window frame goes in
  • Top latches
  • Rear roof panels
  • Metal covers for latches
  • Rear window gasket
Try either one of these for some of the parts between the two you should be able to get everything you need. If not you may want to contact one of our Supporting Vendors SSautoSports
Zip Products . .. or J&D Corvette in Bellflower Ca. 800-838-8353
Good Luck in your search and conversion ;)
