teedawg
Does anyone have any pictures on how the storage tray is connected to the car in the cargo area? My didn't come with and I would like to put one back in. Thanks.
The storage compartment got 4" shorter in, I believe, '71. Something about giving more room to the gas tank in case of a rearend accident.If you decide to replace the tray make sure you get the right one there was a change in the style and configuration of the tray sometime in the 70-72 time frame.
This how I secured the brackets to the rear bulkhead on my '73: 1/4" well nuts. The car came from the factory with a steel plate on the backside of the rear bulkhead that the bracket bolts screwed into. I got the steel plates with the tray, but felt it was too much trouble to install them. The well nuts work fine.
Roger
A different forum but think this is what you are looking for: http://forums.corvetteforum.com/showthread.php?t=1595591Does anyone have any pictures on how the storage tray is connected to the car in the cargo area? My didn't come with and I would like to put one back in. Thanks.
...The car came from the factory with a steel plate on the backside of the rear bulkhead that the bracket bolts screwed into. I got the steel plates with the tray, but felt it was too much trouble to install them. The well nuts work fine...
