reduced power on dic
CHARLES
BOSSIER CITY LA.
1998 torch red coupe
yesterday while driving 55 mph on a country road my 98 corvetteshut down to about 800 rpm the dic read reduced power and the check engine light came on i drove it about a mile pulled off the side of the road let it sit about 5 minutes and it cranked up and ran fine however the checjk engine light was still on. i drove home let it sit about an hour cranked it up and everything was fine no check engine light ,no reduced power it was fine whats up?????????????/
Charles,
Your posting questions about your 1998 in the 1990-1995 ZR-1 Forum. Please place your questions in the correct forum. Moving this to the 1997-2003 C5 Tech Forum...
Hi there,
I would recommend that you retreive codes from the DIC, and let us know what you have as far as the PCM, and the TCS computers.
If you do a search here, these instructions on how to do this will show you what to do.
Then, post the codes, and let us know.
Allthebest, c4c5:hb
Have you had the steering lock recall done to the car? This can make the car shut down on power. If you don't know, post the VIN and I will vis the car right now and tell you if it's been done.
