Baldie88
I recently changed the battery on my 2016 vert (a whole other story). I've got all my setting back but I can't get the windows to reindex (goes down about 1/8 inch when you open and close the doors).
The procedure I have is to just put the ignition in the 'on' position. Put down the drivers window and then back up. Put down the passenger window and then back up. Now hold the driver's switch up for about 3-5 seconds. Release and then do this again. Then do the same to the passenger's window. Now raise and lower windows to make sure they work, which they do. Turn off the ignition and get out of the car. Windows do not index. If this doesn't work the first time, do the same procedures again, which I've done numerous time.
I've also seen the same procedures but have the car running, which I've done several times also. However nothing seems to work. I'm sure I'm missing some tiny tidbit of information but so far no success. It's a minor problem and is OK as it, just wanting to get it back to what it should be doing.
And just an FYI, whenever you change the battery, make sure your windows are down and maybe a door is open. There is one cable that even though connected and shows power to the car, if it isn't fully seated the car goes into theft mode and it goes fully locked down. Had a heck of a time figuring out how to get back into the car and fix the problem.
Thanks!
Ron
aka Baldie 88
Thanks!
Ron
aka Baldie 88
