Don61
Hello everyone
, good to be back after a long cold winter.
As some of you may know my 81 is a stock 350 auto. Someone along the way removed the catalytic converter & oxygen sensor & installed side pipe exhausts. The pipes that used to go to the converter/oxygen sensor are just hanging there, crimped off at the ends. I would like to remove the air pump & all of the hoses, etc. & simplify the engine compartment since they aren't doing a lot of good anyway. I have a lot of experience with older Chevys' but none with computer controlled smog engines like in my 81. Is there anything special I need to know about unhooking the air pump, etc? If I just unhook everything & block off vacuum lines & the exhaust port where the pump hoses go in will everything still run ok?
Thanks for any help you can offer,
Don
As some of you may know my 81 is a stock 350 auto. Someone along the way removed the catalytic converter & oxygen sensor & installed side pipe exhausts. The pipes that used to go to the converter/oxygen sensor are just hanging there, crimped off at the ends. I would like to remove the air pump & all of the hoses, etc. & simplify the engine compartment since they aren't doing a lot of good anyway. I have a lot of experience with older Chevys' but none with computer controlled smog engines like in my 81. Is there anything special I need to know about unhooking the air pump, etc? If I just unhook everything & block off vacuum lines & the exhaust port where the pump hoses go in will everything still run ok? Thanks for any help you can offer,
Don
