- Thread starter
- #21
chevyaddict
At this point it is probably safe to say that the manifold is going to have to be re-tapped and have heli-coils installed in a lot of the threads. It will not cost much more to re-tap and heli-coil all of the threaded holes and that will end this problem forever.
So (I love starting paragraphs with And & So) get the bolts out anyway you can. I despise extractors and do not allow them in the shop.
To remove a frozen bold we weld another larger bolt to it. One with a nice big head to get a wrench on. The heat generated in the bolt while welding helps to break the threads loose.
Then we wiggle the wrench back and forth until the bolt finally breaks free. Often the welded on bolt breaks free. Just weld it back on and keep trying. This method is about 90% effective for us. The other 10% are not coming out for love, money or an act of any god of your choosing.
Good luck
But the problem is these are the bolts that are into the aluminum heads.... the actual intake bolts. I really don't want to use heat or drilling on these particular bolts for that very reason... if I weld something onto these bolts won't the heat warp either the manifold itself or the heads?
