nistaf
New member
Original battery (99) is dead. Was going to replace with an Optima Red Top as has been suggested in earlier forums, but a local NAPA specialist said his NAPA Orbital is the same. Any truth to this?
 Nistaf,
I must admit, I have never heard of a "NAPA Orbital" type battery. When I did a Google Search, the results described it at "NAPA/Exide Orbital." How similar it is to an Optima, I don't know.
And I guess in light of that lack of certainty, I'd stick with the Optima.
-Patrick
I've had a Red Top for 2 years and it's worked great! No problems starting when the car has sit for a couple of weeks but many people will tell you about all the problems they've had with them.
I am going to replace my battery and was wondering if there is any need for a memory saver? I found one you plug into the lighter.
hands
Go with a gel cell battery or glass mat battery, your main wiring harness is below your battery. Battery fluid and wiring harnesses/computers do not mix. I went with a yellow top. I also used a memory saver, when I replaced my battery.
BTW the Delco's used to leak.
erd: don't use any "wet" batteryOriginal battery (99) is dead. Was going to replace with an Optima Red Top as has been suggested in earlier forums, but a local NAPA specialist said his NAPA Orbital is the same. Any truth to this?
