zagger
Ive recently had my 6speed trany rebuild, new clutch etc.. To acomplish this the rear end had to be droped and reinstalled. Since I got the car back the handling feels differant to me. I had the car in two shops for an alignment and it still feels like it will bounce off the road. This hapens aspecialy while driving at higher speed or while turning or changing lanes. I noticed the other day that there is a lot more of room in the rear tire well then there was before. If I look at the space under the runing board the rear sits higher than the front. I think the bolts that set the ride hight need to be adjusted, which in turn would stiffen the rear dampening. Does anyone know what is the the stock hight if mesured from ground to the lift points (under the runing boards) on a stock C5?
PS. I'm runing run flat F1 in front and non run flats F1 on the rear. Can that cause the extra body roll or bounce I think I'm feeling?
