Rocker studs RR ????
  • Thread starter Thread starter Mart
I will agree with that, I just did the drivers side and wow what a difference.
Hey Rich, did you do the 1.52 ex and 1.6 intake roller tip rockers, just wondering what your thoughts are on this, along with any setup issues.
Mart
The first time, I did the split-ratio roller tips. It didn't make a hugely noticeable difference, but the engine ran quieter (result of adjusting the lash?) and I think (with no data to back it up) also a tiny bit faster - it wanted to rev quicker.
However, were I to do it again, I'd use FULL rollers, rather than roller tips. Easier to adjust, more of a difference.
[RICHR]
I kind of wanted to stay with the stock valve covers, so I am just trying to figure out what rockers to go with 1.5 -1.6 and are there clearance issues with the 1.6's.
I'm not looking for huge performance gains but a little is always good, right now these are the originals with 220,000 k or 136,000 miles on them. they are in pretty good shape but you know how it is when you get the itch for more.
Thanx
Mart
You'd need to take a dremel tool to the drip tabs inside the valve covers (turn the cover over; they're obvious) and grind them down a bit, but otherwise you can use 1.6's no problem.
[RICHR]
