eoseitz01
Active member
I'm almost done with my 355 project. I finished adjusting the rockets and installing the intake last night. I started to put the valve covers on and ran into a problem.
The valve covers go on, but it appears the baffle is hitting where it slides between the rocker arms. I noticed a lip on one side of the edelbrock valve cover. Can I put them on backwards? Right now I have the lettering facing up on both sides. Will it hurt to remove the baffles?
I noticed on the passenger side, rocker #6 looks slightly turned. I don't know if the valve cover moved it or if I have the push rod guide on slightly off. Can I take the lash out without removing the intake if I readjust the push rod guide?
Sent from my iPhone using Tapatalk
