sad 1st time vette owner
  • Thread starter Thread starter carpenter
C
carpenter
Just found out that the transmission on the 85 is totally trashed :cry Now looking for replacement transmission.
Automatic or manual? :confused
The auto is less expensive than the Doug Nash 4+3 at least! ;)
_ken
[size=-2]...and don't listen to Keith or anyone else when they tell you to replace the DN 4+3 with a six-speed or other trans! Just get it fixed right the first time!![/size] :L
Not sure what to do yet... weighing my options. Does anyone have any info. on a direct T5 swap? Having a hard time finding any 4+3s. 6 speed sounds nice, but man their expensive!!
Is it the overdrive unit, or is the four-speed (the T-10) that's damaged?
_ken
The T5 doesn't go into a C4 real easy and it's not robust enough, if you plan any engine modifications. In fact, the older T5s are marginal for a stock 350 in a C5.
The ZF six-speed can be retrofitted to the pre-89 C4s but it's somewhat expensive.
A good choice is the Richmond six-speed. In fact, Richmond sells a special "kit" for upgrading 84-88 C4 manuals with its six-speed that is said to include everything you need for a bolt-in swap for the car's existing Doug Nash
If the car is paid for, you can always take a low interest title loan at the bank to cover the swap. Nice part about that is you are investing right back into the car, it is a secrured loan with set payments, and it is part of making an overall improvement to the whole package.
The aftermarket six speed would be awesome!
I don't know if you guys know Mel Foye over at ChevyTalk, (I know him from Corvette gatherings here in SoCal in the past), but he said that he's had problems with the Richmond six-speed in his '62 Vette (Ya can't miss it -- everything on that car except the seats and tires, is YELLOW!). :L He has had it pop out of gear, says it's hard to shift, etc.. :(
I was gonna go that route, but I think I'll stick (NPI) with the DN 4+3. :gap
_ken
4+3 on ebay
Linda:
There is a 1986 4+3 transmission for sale on ebay (#597113141). It looks like the overdrive unit is with it. You can buy it now for $570. or bid on it. Seller is located in Acworth, GA.
__________
:cool
Al
It's both the overdrive and the four-speed. We were hoping it was just the overdrive, but the whole thing is toast. I found some 4+3s and am calling around for pricing. Still undecided.:confused
Here's a very rough picture of the car.
You're right Keith, that is (or will be ;)) a very nice looking ride! Custom paint, eh? Looks good!! :upthumbs
Too bad about the Doug Nash. :( I just may re-think my position in regards to swapping the DN 4+3 for a Richmond 6-speed, or some other trans.
I'm pondering that, because mine is acting stranger than ever. :crazy
I just got back from cruising the canyons around LA (from here at the beach to out in Simi Valley) and the thing functioned, for the most part, as it was designed to work. Even as I was going uphill through the canyons in second and third gear!
If I would kick the throttle past 60% depressed (or whatever it is - I forget), it would kick out of OD as designed and when I returned to normal cruising, and re-set the button, it engaged just as it is supposed to engage. :mad
Stupid #@$%*&&)><@ transmission!! :r
_ken :L
Me too Keith, but I put my foot in my mouth so much lately, I figured I should clarify my statement. :Silly
_ken
Torque Shop
Dream Giveaway
