Dad
- Joined
- Nov 18, 2001
- Messages
- 611
- Location
- West Unity OH
- Corvette
- 15Gray/8sp 72Blk/Blk4Spd 64Red/Red/Wht4spd
Valves???
Not sure there are any liquids that will add metal to valves, that was not a required repair. Setting the vacuum showed no indication of bad valves, sticking valves, worn guides, weak springs, bad rings, poor timing, carb settings, leaky intake gasket, plugged mufflers, or leaky head gasket.
The rebuild to this carb was lame, accelerator pump was not hooked up and the metering needle carrier was in backward. Engine ran but as you can imagine it fell on it's face when you tried to accelerate. The past owner just nursed it to shows and polished it, I almost think it is (was) the same oil that was in it when he bought it. Rebuild was done 10 years ago and my hope was that the Sea Foam would remove any buildups that were keeping it from running more smoothly after the above was fixed. Didn't happen, got very little smoke when I ran it through and even after the soak it put out nothing. That's why I mentioned the leakage of some gas in the throttle rod pivot. Address one problem at a time until the issue is gone.
On the other hand the issues in the carb may have come from someone trying to fix an ignition problem by working on the carb, that was screwed up also and was dealt with first. You can never tell how many monkeys have been at the zoo before you got there.
The engine was a complete tear down, clean, and rebuild at the same time the carburetor was done, (hopefully not the same guy [monkey]). Runs great, no smoke, choke, puke, or death rattle.
Sea Foam will not fix a badly needed valve job![]()
