hokie04
I have a 64 Vette with a 327 - 300 hp engine. It was rebuilt by previous owner and he installed a Comp Cam 268H which I believe one step above stock.  The question is stock timing is 8 BTDC. What should the timing be with this Comp cam and also the idle RPM. It seems to like between 700 and 800 RPM with vacum advance hooked up. Currently the timing is set a 8 BTDC and idles best at 800 RPM. With vacum plugged it will idle at 500 to 600 fine.
