sscam69 said:
Hey Chris
What were you shooting for? Are you thinking about swapping out the cam, or are you going to take it to get redynoed first?
I have no plans on swapping the cam at this time. I want to first make sure/determine where and why the base line is where it is on my ride vs. the adverstised potential of this engine package.
You see, this is poetic symbolism. That is, my dyno image is just as small as compared to what you would prefer to see, as my actual numbers where in comparison to what I wanted to see. Actually though, I can't really figure out how to use my scanner and create images that are any bigger.
I duplicated to the last detail Edelbrocks 539 hp test mule. That is the RPM Heads, Cam, Crane Gold Series Rockers, Speed Pro pistons, ring gap, main and rod clearance, .060 over bore, header diameter (well very close at least), RPM cam, and topped it off with the Air Gap manifold and the EFI conversion.
I had thought worse case scenario that she would pull in the very high 300's or low 400's at the rear wheels, and best case to be at the high 400's to a possible extremely low 500 hp at the rear wheels. So, you can see how (if you can read the dyno print) what a shocker it is to be so far off!
Is this an embarrasement? Yes! Add up what I spent buying those parts and you will find I spent a freakin fortune to make no more power than a very hot small block!
I just can't imagine where I went wrong, or if the dyno is off, where is it off, and by how much. My guess is at least 100 hp off. If that is the case, then I am just bumping the low end of the range I thought I would hit on the worse case scenario. Which means it is still a BIG dissapointment.
So, how do you deal with this? I actually made Nikki a promise to let the car rest for a while now that Sharkfest is over. So, to vow true to my words and respect for her request, Killer sits out in the garage right now collecting dust. To add insult to injury. Sitting out in the hot sun over the labor day weekend appears to have caused my bonding agent on the front inner fenders to reactivate to some degree and create a distoration on the outter surface of the front fenders! I first noticed it getting the car off the trailer back in Florida on Monday afternoon. The only solution I see is to block the nose of the car back down and reshoot it!
Here is the dyno curve from the test mule at Edelbrock. Only difference being this is at the flywheel, and it is a carb and carb intake vs. the Airgap and EFI
Here are all the specs, which are near identical to my engine.
Edelbrock Performer RPM Power Package Components for
454 c.i.d. Chevrolet:
Edelbrock Performer RPM 2-O intake manifold..........................#7161
Edelbrock Performer RPM camshaft kit.................................#7162
Edelbrock Performer Series carburetor (750 cfm, manual choke)........#1407
Edelbrock Performer RPM aluminum cylinder heads......................#6045
Edelbrock timing set.................................................#7810
Edelbrock valve springs
(supplied with Edelbrock Heads; iron heads use #5762)................#5745
Edelbrock retainers
(supplied with Edelbrock Heads; iron heads use #9731)................#9715
Edelbrock valve locks
(supplied with Edelbrock Heads; iron heads use #9612)................#9615
Shortblock Components:
Bore........................................................4.250" + .060"
Stroke......................................................4.000" (stock)
Crankshaft............................................factory forged steel
Rods.........
factory (polished and shot peened) 6.135"center to center with ARP bolts
Pistons.................................................TRW #L2399 + .060
Rings......................Speed-Pro #R9590 + .065, 5/64" x 5/64" x 3/16"
Head Gaskets................................................Fel-Pro #1017
Test Engine Specs:
Main Bearings (clearance)...........Michigan 77 #MS 829 H (.0026"-.0035")
Rod Bearings (clearance)............Michigan 77 #CB 743 H (.0022"-.0025")
Piston Wall clearance............................................. .0065"
Ring End Gap clearance.................top ring .018" - second ring .014"
Rod Side clearance................................................. .020"
Compression ratio...................................................9.6:1
Ignition and timing...........................36° @ 3000 RPM + MSD 6 A box
Headers.............2-1/8" Primary, 32" long - collector 3-1/2"- 10" long
Edelbrock Performer RPM Aluminum Cylinder Head Specifications
Intake port volume..................................................290cc
Exhaust port volume.................................................100cc
Combustion chamber size.............................................110cc
Crane roller rocker arms.........................................13750-16
Intake valve size..................................................2.190"
Exhaust valve size.................................................1.880"
