magicv8
If you put a voltmeter on the solenoid when the Battery meter reads + 40, you may find the battery is 12.6volts. If you also put the voltmeter on the horn relay at that time, it may read 14.5 volts. The Battery gauge reads the difference between the two places as +40 meaningless approximations of amps or something.
When the Battery meter reads negative, the solenoid probably reard something like 12volts and the horn relay may read 10.4volts - which the Battery gauge interprets as -40 meaningless units of gauge face.
If you want a reality check, put an ammeter on the battery or a voltmeter on the battery or dash circuit. I put a voltmeter on the instrument cluster.
