KOPBET
So the #2 sense tab is connected to the horn relay and #1 field tab is switched through the ignition and the idiot light? BATT is routed through the ammeter to the battery + ?
KOPBET said:So the #2 sense tab is connected to the horn relay and #1 field tab is switched through the ignition and the idiot light? BATT is routed through the ammeter to the battery + ?
67HEAVEN said:Midyears don't have idiot lights, except the one shining over the driver's head when I open the door.![]()
KOPBET said:Well, I've never had the pleasure ... :cry
67HEAVEN said:Now we're getting into a stock versus modified scenario. The stock setup included a 4-wire alternator and an external voltage regulator (4 connectors), while my current 3-wire alternator has an internal regulator and aftermarket jumper assembly to bypass the old external regulator, (which I left in place to fool the judges).![]()
My head hurts.
From what you describe, that would seem contradictory to me. You are at 14.2 volts. If the voltage regulator was bad, I would think that the output would be either well above 15v or nothing.It seems as though the internal regulator is kaput.
If this is the case isn't the the ammeter is between the + source and a load point? You would always have current here (i.e alternator output current), would you not? If you wanted zero out (no battery charge current) on the ammeter, wouldn't you want it between the alternator output and the battery (solenoid +)? My brain hurts. :crazyThe ammeter was, and is, routed to the starter solenoid (thus BATT+) and the horn relay.
67HEAVEN said:KOPBET, Here's a photo to help keep you happy until you do....
Another link to the MAD website... this one about Regulators which uses an excellent analogy to describe the relationship of alternator, regulator and battery. An alternator can't produce more voltage than it was designed to produce but it can push continually push more amperage than is necessary to maintain the system. The battery acts as a buffer but continual overcharging will damage it.KOPBET said:From what you describe, that would seem contradictory to me. You are at 14.2 volts. If the voltage regulator was bad, I would think that the output would be either well above 15v or nothing.
-Mac
Too many amps..............not enough ohms (resistance).
67HEAVEN said::Silly
Voltage ain't the problemo. As noted above, it's a constant 14.2 while running.
However, the in-dash ammeter (and my multimeter) both indicate a constant +40 amperes situation.![]()
So, let's put KOPBET's Ohm's Law to use.
V = I × R
V = voltage in volts (V)
I = current in amps (A)
R = resistance in ohms ()![]()
In a "normal" driving scenario for a midyear:
V = I X R
14.2 volts = 2(? guesswork) amps X 7.1 ohms
My driving scenario:
V = I X R
14.2 volts = 40 amps x 0.355 ohms
What has this taught me?Too many amps..............not enough ohms (resistance).
I know.Disconnect the Ammeter (the in-dash gauge marked Battery)![]()
and fergetaboutit.
67HEAVEN said:What has this taught me?Too many amps..............not enough ohms (resistance).
Great idea! :L Better yet, send it to me! (the car too, not just the ammeter)67HEAVEN said:I know.Disconnect the Ammeter (the in-dash gauge marked Battery) and fergetaboutit.![]()
SPANISHVETTS said:If the Alternator is putting out 14.2 volts there is no way that you are charging 40 Amps. Your problem is more than likely in the wiring. The Amp meter may be indicating the total current flow or at least the flow through some circuits instead of the charging current.
SPANISHVETTS said:Your problem is more than likely in the wiring.
SPANISHVETTS said:With the voltmeter connected to the battery positive and ground compare the voltage with every thing turned off and then with every thing turned on. After a few seconds the two readings should be close to equal.
magicv8 said:It actually is a galvanometer reading the voltage difference between the starter and the horn relay.
magicv8 said:The gauge reards BATTERY. It actually is a galvanometer reading the voltage difference between the starter and the horn relay.
door open (courtesy lights on) -05 reading
add parking/tail lights -15 reading
add low beam headlights -20 reading
