I know nothing about the Lt setups. Where is this module located ? You seem to have it isolated to heat soak but why now and never before ? Something change? I would be worried about what causes the heat issue.
Would the bad ground have caused the module to get high amperage and damage it to make it more sensitive to heat,which in turn means it is planning on failing ?
This all just seems to be a strange turn of events.
Glenn
I've had a couple different Modules,TPS's,IAC's,ECM's and Mass Air Flow Senors on it in the past 2 weeks trying to Isolate the problems I've been having!! Bad ground at the back of the engine was what I think was causing the Idle and Dieing problem!! The whole problem started about 2 days after I used some new fangled engine 2 in 1 Degrease and Shine by Black Magic that was at advance auto parts on sale 2 for 1!!
The can said............
"No Wrapping Required"
"Cleans,Decreases and Shines in 1 easy step"!!
"Safe for ALL Engine parts"!
"No Pressurized water Required"!!
Just spray on warm engine,allow to stand 15 min and rinse with light flow of water!! Run engine till dry!!
As far as why I think the last 2 times is Heat Soak,I have driven the car 5-6,000 miles since I've had it and never had one problem,But I have NEVER drove it Like I stoled it!! Both times that it has done this the last 2 days,I've been driving it like Mario Andriette and it was performing Perfectly for several miles and I shut it off for 10 -15 minutes!! 1 time it set a code Smoked Black,Popped,Missed and Backfired but started cleared out and got me home, the second time it smoked and missed a little and cleared out and ran good!!
After looking,thinking about it,shooting the Ignition module with my IR gun and finding it about 200+ deg,I decided that the way it's mounted don't make any since!Why lay the heat sink flat against the steel bracket that is mounted flat against the head to absorb that heat too!! So I made a insulator out of 1/6th thick neoprene gasket material that covers the complete back side of the heat sink between the steel bracket,used dielectric grease between the module and heat sink!!
I've took it out and flogged heck out of it several times now,it's not had any problems starting after shut down,and the module has never been over 168-175 deg since!!
I've never had this problem before,but I think this will become a Standard "GMJunkie" Modification on 92-96 LT1/LT4 engines!!
