John Robinson
Gone but not forgotten
Stay tuned
I have found a cracked plug in #8 today but the really big discovery is with the new wires I put on when I changed the plugs. On #8 & #6 GM used a straight boot to cover the plug. the new set of wires had two wires with straight boots and were the right length for these two plugs. The problem I discovered today is that the straight boots are too long and therfore the plug does not go into the solid connector inside the boot. I will be correcting this problem tommorrow by cutting off at least 5/8" from the length of the boot. I hope this will be the answear to my miss when it gets hot. I am not an engine engineer but I think I heard somewhere that when the engine is cold it takes less spark to fire the cylinder but when it gets hot it requires a hotter or stronger spark. If this is true then it would explain why the miss came on at 190F.
I hate to
