Spark Plug Wire Loom
Yeah, I remember seeing that. I'm just trying to keep my current wires b/c they have less than 3000 miles on them.
You could prob cut and re-crimp the ends if you wanted... just take care in removing the boot so you don't cut it up. Use some dielectric grease in the boots before you try to put them back over the ends.
It's pretty easy to cut em... just grab a razor blade and cut the length you want plus 3/4 inch. Then splice down to the core (Be careful not to cut). Roll the cable 360 with the blade resting on the core... pull off the spliced end. Bend back the core and crimp the end on. Lube your boot, and pop it on... you are good to go.
thanks 74bigblock. I got the wire looms in the mail today. They will look perty once I put them in. Unfortunately, I have to wait to put them on until I put my side exhaust on. They will not fit over my stock manifolds w/ the AIR tree/bung/hideous-looking-thing.
