C
corvgreg
The L48 pistons in 71 were dished with 4 valve reliefs...I don't know the cc volume of the dish though.
Yes the 487 head was used for both engines with the differences noted.
The LT1 had magnufluxed and shot peened rods, otherwise the same as the L48.
I ran a Crane HMV272, .454/.480 lift, 216/228 duration at .050. I'd recommend better valve springs and flat top psitons. This cam had a little lope at idle and was strong in the 2000-5000 rpm range. It also is legal for smog. I liked this cam and it was in a 71 L48 4 speed car with performer intake, rejetted q-jet, recurved distributor, and 2 1/2" exhaust. If you want to make a lot more power you'll need to run headers and improve the flow in the heads.
Greg
Greg
