Johan
I'm installing the rag joint, but the gap between the coumn shaft and the steering box shaft is a bit too big.
Is there anything I can do to adjust this? The column shaft end to bearing face is 4,5 inches (correct for a 69), so I don't think the coulmn is collapsed. But is there any way to extend it a bit? I have the column out of the car now.
I should add that I have done a frame-off and switched to a new frame, so it is a "new" setup.
