Peer81
Yesterday I found a problem with my steering pump.
After I rebuild the pump I reinstalled the pulley using a normal press no problem so far. I think I pressed the pulley to come even with the axle front without any excessive press force. But after I installed the pump I noticed the pulley no being in line with the crankshaft pulley. So I shimmed the pump between the pump bracket and the engine so the intire pump moved a little forward. But it still isn't enough the pulley still needs to move a little 1/8 to 1/4" to the front. Here is the problem, I found out the alternator beld is now touching the front of the ps pump... So with the shims the pump is already to much to the front and the pulley still needs to move a little more. And yes I have the right pump, pump pulley, bracket and engine.
Is it possible to move the pulley a little to the front with the removal set or is it only a tight press fit at the end of the pump axle?
Greetings Peter
Greetings Peter
