1972 coupe with tilt / tele and A/C
Ok here is the problem. The horn doesn't sound when you press the horn button. It does sound sometimes when you turn the steering wheel!
I've verified that the issue is in the column. (the horn works fine at the "harmonica connector" at the base of the column)
Also the key buzzer is stuck on. (when I ground the door jamb switch it buzzes even with no key in the ignition)
Question is.. what brand/model/part number steering wheel puller should I buy?
Should I even attempt this? or will I just screw it all up. How hard is this to do? Any advice? Things to look out for?
Thanks!
-Gooney0
Thanks!
-Gooney0
