D95
I installed the B&M super cooler.It was installed in front of the a/c condensor at an angle (it does not touch the condensor) It has great air flow. My vette is a stock 95 LT1 with a dewitts radiator. The cooler was installed going thru the rad cooler first then thru the B&M cooler. The cooler was installed using rigid metal lines. While driving on the highway at 55-65 mph,for 25 miles the trans temp was at 215. The water temp was 198 and the outside temp was 65 degrees. Should I get a larger cooler or should I run the cooler so that it does not go into the radiator cooler? Living in NY (winters) I dont want to make it too cool (but I doubt that that will happen with this car) I can really use some help
thank you
B&M 70273 - Transmission SuperCooler
thank you
