1989 406
Boy am I still having a really tough decision. I posted on here before about coming in contact with my father's 1989 Convertible Supercharged Vette. The car was supercharged, roller rockers, 3:73, fuel pump etc, about $10,000 back in the early 90s. It ran in the high 12s on 6 psi and low 12s on 8 psi.
After seeing the car over I was told the injectors were all clogged and gas dripped and burnt a hole into one of the pistons which was replaced, due to not being driven enough over the years.(It has 59k on it now, we got out of it with about 28K around 92, Carfax says it is legit).
The guy also says the supercharger is bad because when you pull off the tube you will find oil. It got up to 6 psi and then dropped.
The problem is that I could probably swing the car, but not to keep putting thousands into it which I know Vettes are known for.
I think that I could find a a non supercharged Vette. , but I would not be able to build it to the specs of the 89 due to cost. The 89 was built solid when it was done.
I keep going back and forth about what to do. I know the obvious answer is to pass. But then again if the car only needs some work, I would have a solid 12 second street car.
It would kill me to know that if I passed on it, I would keep thinking I did the wrong thing, but if I buy it and it cost too much, I would kill myself. This is probably a psychological issue!
And of course the sentimental thing of it being my fathers originally, plays a big part.
Please help with any thoughts.
Thank you.
Thank you.
