Which settings are you talking about ?If you don't mind reprogramming ALL your settings, just disconnect the ground cable from the battery. Should you NOT want to have to reprogram all those settings, use a Battery Tender.
I prefer the tender myself. But to each their own.
How to prevent accidental short. My negative clamp has no plastic cover
What could it short
Contact with any metal parts?
When I store my 08 for any length of time I disconnect the negative terminal .I've found that the car will reprogram everything automatically after driving 10-20 miles .Short term storage 2-4 weeks I use a tender when possible .
I believe that in the C5 owners manual GM actually recommended disconnection of battery for long term storage .Never read the C6 manual![]()
So as long as it's not directly touching the Red, positive, or HOT cable you're "Golden!" (Fine)
It wouldn't matter if it does, if the battery cable is disconnected.
In fact jumping the disconnected ground cable to the positive cable is one of the approved ways to discharge the capacitors in the electronics for memory clearing.
April 1st is coming out day for my 3lt 08 convertible .It had been stored in a cold dark garage since last November with temperatures as low as -20 for days . I felt bad that it didn't winter with me in Florida but she doesn't like the traffic .Anyway I hooked up my battery negative terminal pushed the start button and we backed out of the garage .I check for oil spots on the floor ,checked oil level and tire pressure .I started the car and while waiting for the car to come up to temp a little .It took me less than 2 minutes to index my windows and reset the memory ,the car did the rest .![]()
Side note I bought the car new and presently have 76,000 miles on it with no issues ,Runs just like my Fords .
