S
sac001
OK, about 2,000 miles ago, I rebuilt the Rear differential and Trailing Arms. While I was at it, I had the U-Joints on the half shafts replaced, replaced the brakes, e-brakes etc. Essentially I had everything from the driveshaft back rebuilt, all new hardware, poly bushings etc.
Now, when I start out, I'm getting a strange noise from what appears to be the Left rear wheel. It doesn't have the heavy Clunk of a U-joint problem, sounds like maybe a spring or a stuck or sticking emergency brake, but it happens whenever I change direction, regardless of if I used the e-brake or not.
I've pulled both rear wheels, and can't find anything obvious, no rubbing scraing hitting or anything of the sort. I've checked the differential fluid, and re-lubed the grease fittings on the half shaft u-joints.
It almost sounds like something is moving in relationship to the change in direction of the car. Is it possible that if one of the bushings isn't seated correctly that this could happen?
Anyone have any ideas or help, I'm pulling my hair out on this one and don't have much left to pull!
Steve
Steve
