brusso
I have a stock 75 w/350 auto. How do you remove the power steering cap without removing the alternator pivot point bracket? I can only open the cap and pull it out about an inch before it hits this bracket.
C3forME said:Once I replaced it with the correct pump and correct belt I was able to remove it, although it still is no picnic and very dangerous to do with the motor running because the alternator belt is so close to the cap.
78SilvAnniv said:I certainly hope you were kidding about trying to remove the ps cap while the engine is running.
Trying to do that could cause mass quantities of skin and apendages to become irreparably damaged and/or permanantly removed by the moving parts. :eek
I would never attempt that with my 78. Are other vettes different in that you can access the ps cap while the engine is running!?
Heidi
C3forME said:Heidi,
I would never suggest trying to take the cap off with the engine running, it is way to dangerous. The engine definiately has to be off. It's hard enough to get it off when the engines not running!! :eek
