kobi67
This week on the way to work, the T.I. module went out on my 67. I took it apart and found moisture in the case, most likely causing the failure. The transistors are GM parts without any #s that will tell me what their specs are. Has any of you guys ever repaired the module, and what transistors did you use?? I found T.I. Specialty and they sell replacement boards. I think my board can be repaired for a lot less $$, If I can find the right transistor... Thanks, Kurt
