T-top Assembly
Mooser
Ontario
1972 BB Coupe
Anyone out there have access to the AIM for a single lever (79+?) T-top?
I'm putting mine together and wanted to know where they put sealant or adhesive on the trim.
I've got the original AIM for the car (72) which I can use as a guess/guide but since someone converted mine over from double to single levers a long time ago and I've got both sets of glass and painted tops I'm leaving it.
Mooser
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
are you trying to put weatherstripping on or are you reffering to the rubber piece that goes around the outside edge,or some other part(s)
Mooser
Ontario
1972 BB Coupe
T-top
Mainly the piece of stainless trim along the front and outside. But also anything related to the inner skin, weather strip etc.
When the tops were painted all of the trim (stainless) was removed. I've polished everything and now that I'm putting it back on I want to make sure I've put adhesive or sealant in the right spots and haven't missed anything.
Thanx
Mooser
bill81vette
Moderator
Troy,NY
do you have glass or fiberglass tops???
Mooser
Ontario
1972 BB Coupe
T-tops
Actually, both...
The glass ones have the black rubber/plastic along the front and outer edge and it is still together (since it didn't need paint :)
The one with the stainless I'm putting back together are the regular fiberglass ones.
Mooser
