Turning in Rt. will make it hold in gear a little longer and then will shift Ouicker & Harder, turning out Lt. will make it shift sooner and Softer!! (More Cushy) Dave did you get your Passing Gear switch working?? If not get that fixed first and try!! Turning in little screw can make a Heck of a diff!! Don't over do it, just a 1/8-1/4 turn at time!! and no farther than 1 turn!! and make shure you have good Vac on line going to it First!! If you over do it it can Brake diafram in Modgl. Just puting a New Modgl. may do what you want if old one is weak!! $15.- $25. If diafram is bad it will suck Tranny Fluid through vac and Make it Look Like James Bound opened up a Smoke Screen!!
junk!! P.S. Don't Change Conv. Stall It will probly make your Gas Mileage go to ****!! (if you have any)
