In all honesty, the hardest part of this job is cleaning all the parts.
Setting up the bearings is really not all that hard. . .as long as you have access to a machine shop who can grind the shims down for you.
A friend of mine used the BUBA grinding method. . .where you use a hard FLAT table, a sheet of emmery cloth (150 grit black) and sand each side of the shim, turning the shim 1/8th of a turn after every three strokes, to the desired thickness. It took a damn long time. . .but it seems to have worked for him. I'm not recommeding this. . .but it is a nother option.
Other tools I HIGHLY recommed:
1) The Lisle bearing race and seal install tool. (there are other brands like OEM who make this tool . . .but buy American. . .they are compareable in price and Lisle are made here). You can get them at Sears, or Farm & Fleet.
This tool is used to safely and properly install bearing races and seals. It's impossible to install the seals on the TA with this tool. . .but they work great for the front bearings and seals as well. The driver attachments have two sides. One side is "conded" with a flange, to drive and seat the races. The other side (flange side) is used to seat the seal for that sinse race flush with the housing.
Note: This tool (or any others that I have found) does not come with a driver attachment that correctly fits the inside race of the TA. For the inside race, I recommed using the "seal" side of the largest driver, and get the race started. Tou should be able to installl the race down untill the driver attachement seats on the lip where the seal would normally sit. Then switch to the second largest "seal" install attachment and drive it the rest of the way.
Once installed, try to spin or move the race in any and all directions. . .if it moves at all. . .get a new housing.
2) The Lisle seal puller. Mighty handy for pulling old seals.
