W
wade
i am having troubles [i think] with my torque converter clutch not engaging. I have just gone up and down the road one hundred times from 1st to 4th gear while selected in overdrive, and iam only counting the three shifts. rumor has it when the tcc locks up it should almost feel like another gear has just engaged. is there any easy way of checking this out? I do have the gm manuals, but haven't got around to looking in depth at them yet. from what i have seen, they say the clutch should engage at about 25 to 30 mph while selected in overdrive.
Also, i also think that my maf burn relay may not be working.
I have been told that you can hear it working if you are in a quiet
place when you turn off the car. CAN'T HEAR A THING. what way can you check this out? should this not set off the check engine light so you can get the code? any help on these two matters would be greatly appreciated.:confused :confused
