Question: TCS & Active handling System warning light
Mike09corvette
New member
TX
2009 C6
2009 C6
I've just gotten these warnings. Is this something I can correct myself? If yes, how? Or do I need to have the dealer correct it?
Thank you,
Mike
Do you have the factory service manuals? They would step you through the process to figure out what needs to be done.
2009 C6
Thank you,
Mike
The dealer is probably your best bet. If you can have the codes pulled and see what they are you can probably make a decision based off those. If not and there isn't a Corvette specialty shop in your area then the dealer may be the choice, they have the knowledge base (hopefully they know how to find it and use it) and tech line help if needed.
They are something you can correct yourself if you have:
1) Factory Service Manual or a subscription to GM ESi.
2) A scan tester which supports a 2009 Corvette's chassis computer
3) Basic electrical system service experience
4) Tools needed to work on the car's electronics
Otherwise you need to see a GM dealer or an independent shop familiar with working on late-model GM products
